Old 09-11-2008, 11:21 PM
level1stealth level1stealth is offline
civic ac/heater
i was woundering if a 88-91 civic ac/heater control unit fits a 88-91 crx???
Old 09-11-2008, 11:51 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: civic ac/heater
It fits but will not work. The crx has electronic controls for directional control etc. Plugs are all different except the ac button and fan speed.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 09-12-2008, 12:41 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: civic ac/heater
You could make it work, but you'd need the cables and such from the Civic that you took the control from... the CRX has the same airbox, iirc, you just need to remove the motors and replace them w/ the cables... You'll also end up with extra wiring under your dash, unless you take the time to cut it out...
Honestly, it's not worth it, when you could just as easily find a CRX climate control bezel.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
