Old 09-11-2008, 08:38 PM
acewelderman's Avatar
acewelderman acewelderman is offline
Air shocks for k1500
Need to mount a snow plow to a truck with tortion bar susp, I dont know of any other way to beef it up enough to handle the plow.
This truck is a very heavy duty half ton,Tow packge,Plow prep,3.73 gears,32 gallon tank,Fifth wheel plate.
I have looked but dont find air shocks for the FRONT!
Can anyone find me a link to someone with the shocks I need or have a better idea to beef up the tortion bar set up I have?
Thank you Acewelderman
JUST WELD IT !!
Old 09-18-2008, 01:28 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Air shocks for k1500
I haven't seen any air shocks designed for front suspensions either...typically they're for load-levelling the rear during trailering as you probably know. You might consider a stiffer torsion bar (find some from a K2500 or 3500 or from a AM off-road mfr) or at least cranking down on the adjusting screw. No room in there for air bags with the 4wd setup.
Doesn't the plow mfr have any advice? They'd know what is needed to run a plow on just about any truck.
[UPDATE]
I have seen lifted 4x4s with shock setups attached to the frame and lower control arm. If you can find the brackets used to do this, then it would be a matter of finding air shocks to fit the app...a trial & error process.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
