Old 09-11-2008, 11:13 AM
rt_saab rt_saab is offline
Cryogenic Treatment?
Has anyone ever used this on any of their auto parts? I am thinking about doing it for my brake rotors. I have read that after doing your brake rotors they often last 2x to 3x longer. It seems that a lot of people use it on weak pistons, crankshafts, and connecting rods. I found this site...
http://www.nitrofreeze.com/racing.html
http://www.nitrofreeze.com/cryogenic_treatment.html
What do you guys think?
Old 09-11-2008, 04:20 PM
KiwiBacon KiwiBacon is offline
Re: Cryogenic Treatment?
This is still squarely in the "black art" phase.
Conventional heat-treatments (which have well understood results) rely on the movement of metal atoms from one structure to another. When your metal has cooled to room temperature, there's very little movement remaining and little that can be accomplished (typical exceptions are the aging of quenched aluminium alloys and the diffusion of nitrogen and oxygen through steel to pin dislocations).
The time-temperature-transformation diagrams that accompany conventional heat treatments also stop at 0C (freezing point), I haven't seen any which go lower to lend any science to the claims of cryo-tempering.
So IMO the process isn't understood enough to verify or refute the claims. But do you really need brake rotors to last 3x as long? Many vehicles don't last long enough to wear out 1 or 2 sets of rotors. Let alone 3.
Old 09-12-2008, 07:49 AM
Its a Saab. It'll last that long. My other two did.
Old 09-13-2008, 02:27 AM
jonathanwang jonathanwang is offline
Crycogenic treatment ?This is the first time l hear about it . L know the heat treatment is used to change the microstructure of metal while improve the intensity and the rigidit then increased the part life ,less wear,
Old 09-13-2008, 02:28 AM
Crycogenic treatment ?This is the first time l hear about it . L know the heat treatment is used to change the microstructure of metal while improve the intensity and the rigidit then increased the part life ,less wear, and improved performance.How
Crycogenic treatment ?This is the first time l hear about it . L know the heat treatment is used to change the microstructure of metal while improve the intensity and the rigidit then increased the part life ,less wear, and improved performance.How the crycogenic treatment change the microstructure
Old 09-13-2008, 02:29 AM
Crycogenic treatment ?This is the first time l hear about it . L know the heat treatment is used to change the microstructure of metal while improve the intensity and the rigidit then increased the part life ,less wear, and improved performance.How the crycogenic treatment change the microstructure of the metal, maybe is
Crycogenic treatment ?This is the first time l hear about it . L know the heat treatment is used to change the microstructure of metal while improve the intensity and the rigidit then increased the part life ,less wear, and improved performance.How the crycogenic treatment change the microstructure of the metal, maybe is it useful .L will pay my attention on it in the future.
