Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 09-11-2008, 02:15 AM
towelie towelie is offline
Front Brake Bleeding Issue
Hello, I am a bit confused as to how I am suppose to bleed my front brakes. I only took one wheel off to have a peek and see if I could change teh rotors myself. I decided not to and went to put everythign back but my brakes are getting no pressure or anything....
How exactly do I bleed the lines so that I get pressure back to my brakes?
Old 09-19-2008, 06:54 PM
rhandwor rhandwor is offline
Re: Front Brake Bleeding Issue
Fill the master cylinder cylinder first. Then have a friend get into the truck start the engine pump the brakes appx. 3 times and hold the pedal down. Open the bleed screw then close it do this until all air is out. Note keep the master cylinder full.
