Old 09-10-2008, 09:17 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Steering Wheel Play
So, I've never really noticed until now but I have almost an inch of play in my steering wheel. I take it that this is not normal for the 3S?
Old 09-10-2008, 09:46 PM
mistermoonpie mistermoonpie is offline
Re: Steering Wheel Play
my 97 sl does't have hardly any play. I dunno if its normal or not. If it is normal, I must just be lucky. My guess is something needs to be tightened/replaced
'97 3000GT SL
-Short Ram Intake
-Test Pipe
-Custom Exhaust
-17" Infinity Rims
-Infinity Kappa Component Sound System
-Kenwood Double Din Headunit
Old 09-11-2008, 10:29 AM
Polygon's Avatar
The Red Baron
Just as long as it can be fixed.
Old 09-11-2008, 10:33 AM
spytearbite spytearbite is offline
Banned
You can tighten up the worm gear in the steering box but that takes some experience. The next is the idler arm out of the gear box. This arm is solid but you now walk to that pivot off the arm and you start to move suspension parts and find how sloppy the ball joints are/how the wheel bearings are loose and you move the steering wheel before the bearings move/any suspension arm with a grease fitting is a loose ball joint about to stay in place before you take the slop out of the ball joint is you see that wear is how you gained inches in the steering wheel play.
