Old 09-10-2008, 08:45 PM
WROOD1 WROOD1 is offline
97 blazer wiring
I was wondering if anyone could tell me where to find a complet wiring diagram I recantly replaced the motor and when finished i found that i had no power to the fuse box although i do have power to both the starter and altanator and that is it
Old 09-10-2008, 10:42 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 97 blazer wiring
Many local libraries have free access to alldata which is a popular information source for many independent shops. Otherwise you could always pick up a chiltons manual.
Old 09-11-2008, 07:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As said most libraries have repair information.
Some dealers or repair shops may print you off a copy of wiring you need.
AZ online has a little All Data.
But for the your very own stuff and 10 minutes online with a plastic card good for 26.95 US $ You can be set to go with a on line one year sub. for one car all data repair info sub.
http://www.alldata.com/products/diy/index.html
MT
Old 09-11-2008, 09:58 AM
Airjer_'s Avatar
Its not a bad deal if you use it!! The librarie might charge you $.15 or so for every printout. The online deal will give you a ton of information and it only costs you the subscription for the year and as many ink cartridges as you can go through to print off whatever you need. Not to mention the easy access any time from just about anywhere!!
