Old 09-10-2008, 04:36 PM
HeWhoKillz HeWhoKillz is offline
drum brakes
When you stick one screwdriver in the back and lift the lever and the second screw driver in to move the wheel, which way are you pushing the wheel? Up or down? Or is there an easier way of getting the drum off?
Old 09-10-2008, 05:03 PM
spytearbite spytearbite is offline
Banned
Re: drum brakes
Well, you would have to dual-probe that ratchet you are talking about. So, you would push that spring (away with one tool) that locks that screwdriver adjuster. You simply spin the adjuster one way and if the drum does not tighten and you turn to notice which direction you need to move, the adjuster is drawing the shoes back in and away from the drum is now you can remove the drum housing.
Sometimes rust will lock the drum on the housing is just take your foot and kick the drum itself to break the rust bond.
Old 09-10-2008, 05:40 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: drum brakes
The little paddle is there to make sure it rachets only in the tightening direction. So, move the star wheel in the only direction it goes, then you know that loosening it would be the other way. Then you hold the locking mechanism out of the way and go the other way.
Drums should slide off with very little interference, so expect some other issues. If you let them go too long, they wear grooves into the drum requiring the procedure you're talking about.
Dragging people kicking and screaming into the enlightenment.
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: drum brakes
You could start by trying to rotate the starwheel adjuster without holding the lever away from the adjuster. One way you will be able to spin the adjuster, one you won't. You need to then hold the lever out of the way and turn the adjuster in the direction that it would not turn before moving the lever out of the way.
-Rod
Old 09-10-2008, 05:46 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: drum brakes
To add to spytearbite's post.
The adjusters have a right and left threads. From the back side you need to pull the star wheel down while holding the adjuster with another tool like spytearbite said.
If you've got the drum moving and it feels like the brake shoes are holding it on you will feel like springs are pulling back on you. However, if you can't budge the drum it's more than likely rusted to the hub. I've taken a big hammer to the drum (around the outside edge is different spots (around the outside edge is different spots) and have even gone as far as taken the blue tiped wrench (torch) to heat the drum to expand it to break the rust bond.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 09-11-2008, 01:16 AM
curtis73's Avatar
Re: drum brakes
Very good point, LeSabre. Determining what is holding it on is a good starting point.
