Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 09-10-2008, 07:40 AM
Effian Effian is offline
changing spark plug
I have 1995 Buick Roadmaster. I'd like to change its spark plugs. According to Haynes repair manual you have to reach them from underneath the car, but, I still can reach some of them either from the top or the bottom of the car. Do any one has any idea?
Effian K
Old 09-13-2008, 08:02 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: changing spark plug
Whatever is convenient for you, no manual can dictate how to change plugs. I change all of mine from the top. You just need to be creative with the short extension and universals.
Old 09-29-2008, 09:40 AM
1995LT1 1995LT1 is offline
Effian: I have a 1995 as well. I found the easiest way is to jack up one side at a time, take the tire off and access the plugs through the fender well. I cut some slits in the rubber "boot" hanging off the fender well to allow easier access. Good luck!
Old 10-01-2008, 04:37 AM
bennylw's Avatar
bennylw bennylw is offline
There are, as said, many ways to change them. Here is a worddocument I found:
http://buick.lloyd-willner.se/docs/s...nge-on-lt1.doc
I can´t remember where I got it and who wrote it but thanks whoever You are
It is a bit tricky the first time but as You find Your own way it´s no biggie.
good luck!
/Benny
Benny Lloyd Willner
Värmland Sweden
"4 cylinders is only half an engine"
