Old 09-10-2008, 07:08 AM
SkinCarver33 SkinCarver33 is offline
Serpentine Belt Info Needed
2002 GX 3.5L DOHC
The pulley for my AC compressor is gone bad, and I'm having trouble finding the info I need to make the decision on how to fix it inexpensively and efficiently.
I cannot find any diagram for the serpentine belt routing. If anyone can point me towards a link for this info, or give me a pic of theirs or something...That would be a help.
Also, does anyone know if any 02's came without AC. This way, I can simply buy a shorter belt to bypass the AC compressor pulley.
Also...some pulleys on AC compressors cannot be replaced and some others can. Does the 02 Intrigue have a compressor that has a replacable pulley or does the whole compressor need to be replaced?
Old 09-11-2008, 02:44 PM
notimprezed notimprezed is offline
Re: Serpentine Belt Info Needed
I don't think there is a diagram on the car. I just changed the belt this morning. When you get a new belt at the parts store the package has the diagram. If you cant find a diagram on the internet I would go to the parts store and copy it or replace the belt anyway while its off.
Old 09-11-2008, 06:13 PM
That's some good advice right there.
I have solution and here's what I found out...
The Intrigue does not have a changable pulley on the AC compressor. There are "bypass pulleys" sold online that take the place of the AC compressor, and allow usage of the stock serpentine belt, however, I have only found them for the 98-99 3.8L.
All models of the Intrigue come with AC, so there are no aftermarket belts or replacement OEM belts designed for the system without AC. I have tried measuring the belt and bypassing the AC pulley. I tried the shorter belt but failed. There is a ridge just left of the crankshaft pulley, on the front of the engine, that rubs the belt. That belt would have burned up in a hurry. No re-routing will be successful either.
The solution here is a bearing replacement. NAPA has a part number cross-referenced with GM that provides a replacement bearing for the AC Compressor pulley. It's inexpensive and avoids the compressor needing to be replaced, and also the cost of having the whole system recharged and setup.
I have found a serpentine belt routing diagram on the Gates Rubber website.
The link to the Intrigue is:
http://www.gates.com/common/part_loc...m.cfm?id=S7031
I hope this helps someone else in the future.
