Old 09-09-2008, 11:20 PM
nimo1782 nimo1782 is offline
Unhappy Help! Knocking noise
Hi Everyone,
I have a 2001 Chevy Cavalier and recently it started making a knocking noise. I have noticed it when parking and turning. Does anyone have any idea what this could be?
Thanks for your help!
Nina
Old 09-09-2008, 11:23 PM
Jason/RKBA's Avatar
Jason/RKBA Jason/RKBA is offline
Re: Help! Knocking noise
Need more info. In what vicinity is the noise coming from?
Old 09-09-2008, 11:30 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
If you think its coming from the suspension there are a couple of known issues with these style front ends.
One is the rear bushings on the front control arms. The rubber separates from the metal sleeves that are pressed into the control arm. If this is the case and they are bad enough the lower control arm will be sitting on the subframe and you will see the rubber bushing sitting right above it.
They other is stabilizer links which typically break.
Old 09-10-2008, 12:36 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
which engnie? the 2.4's are well known for the bearing going out on the #3 piston causing the rod to knock
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 09-10-2008, 10:38 PM
Thanks to everyone who replied to this! Mine is a 2.2 liter . . . the knocking noise seems to be coming from the passenger side.
It happened today when I was going straight at about 30 miles per hour.
Thanks,
Nina
Old 09-10-2008, 11:15 PM
Jason/RKBA's Avatar
Does it increase or decrease with speed? Is it coming from the front or back? Does it sound like it is coming from the engine?
