Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-09-2008, 09:06 PM
tdf_46 tdf_46 is offline
93 2.0 DOHC Non-Turbo Engine - Power Drop
In 2004 we had a timing belt failure that ended in a used engine swap into our 93. The used engine long block came from Japan we were told.
All the peripherals (intake, exhaust, fuel injection etc) were used from the original engine.
We noticed right away that the new engine did not have the torque or HP (at least the snappy feel) that the original engine had. To this day it still lacks power by comparison. Compression check yesterday, 185-190 on all 4 cyl. Hwy fuel milegage is 27-28.
Is it posible the replacement engine has different cams or something that lowers it's HP output? Any other ideas?
tdf
Old 09-09-2008, 09:35 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 93 2.0 DOHC Non-Turbo Engine - Power Drop
Welcome to AF!
Were any mods done to the old engine that you know of? Check the timing on the new engine, make sure the TDC marks line up properly. Although you would more than likely get lower compression because of that, it's still an option. Any check engine light?
Is it a 2.0 motor for a turbo? I don't know what stock compression for that motor is.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-10-2008, 11:20 AM
Originally Posted by david-b
Welcome to AF!
No mods to the original engine. I knew the first owner, my ex-girl friend. Thanks for reading!
tdf
