Go Back   Automotive Forums Car Chat > Chevrolet > Cobalt
Old 09-09-2008, 12:12 PM
rfletcher rfletcher is offline
05 Cobalt shifter doesn't unlock
I just returned from a deployment and my wifes car doesn't shift out of park. She just left it in the driveway and used my truck while I was gone but I would like to fix her car and get my truck back now. The key goes in fine and the car starts. When the brake pedal is pushed you can here a 'click' from inside the shift lever but it doesn't unlock. The Haine's manual I picked up today from the Autozone down the road is useless. I have been told there is a shift lock relay that is probably bad. Any help would be appreciated as to what the cause may be, how to troubleshoot it, and if there is a way to over ride it just to get the car moved. Thanks.
Old 09-12-2008, 01:23 PM
MZR_47's Avatar
MZR_47 MZR_47 is offline
Send a message via MSN to MZR_47
Re: 05 Cobalt shifter doesn't unlock
Is the driveway steep? it could be smashed into reverse in a weird way, because of the way it rolls back a bit. I know this happened with my friend's stealth. Try to get someone to push it up the hill a tad, then try to shift out of park.
Or it could be the relay. Try both.
MOAR BOOST
Silencer Delete | SPT Catback | Megan Racing DP | TEIN Flex Coilovers | Front and Rear Sway Bars | DBA Rotors | TurboXS UTEC | 18 psi
Old 04-07-2009, 04:28 AM
BUG1959 BUG1959 is offline
Check with a dealer , my 2006 did the same thing and when i took it to the dealer they said the shift knob was on recall, took them 20 min. And didnt cost anything
Old 04-24-2009, 10:58 PM
56pontiac 56pontiac is offline
They will also lock in Park if the battery is low. Had that happen to mine.But also the key won't come out of the ignition.
Old 04-27-2009, 10:16 AM
rodeo02 rodeo02 is offline
You'll have a tiny access door either on the shift console or under the steering colm. Under that hole/door will be a push button to release the ignition key during times of no power.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 05-15-2009, 07:35 AM
dorman68 dorman68 is offline
The dealer had to replace the shifter on my coworker's 05 Cobalt.
