Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 09-08-2008, 06:46 PM
r82udy r82udy is offline
2000 ls with problems
i have several codes p1285,p1299,and p1000 need help asap . i changed the water pump and t stat but it still overheating and the air does not get hot at all
Old 09-08-2008, 11:18 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2000 ls with problems
Welcome to the forum!
It sounds like you're aware that the P1285 and P1299 indicate a CHT over temperature condition. Since you changed the water pump and thermostat and have no heat, it sounds like you probably have a air pocket in the cooling system and need to purge the air from the cooling system.
-Rod
