Old 09-08-2008, 05:39 PM
silverluminaZ34's Avatar
silverluminaZ34 silverluminaZ34 is offline
Pulley Question!
Whats The Diffrence Between A MPS Pulley and a Press on Pulley you would get from zzp. i know the mps? is a two pc. Is there a diffrence from the two pc pulley vs the press on?
2002 GTP 3.4 pulley/u-bend/resonator delete/AL104s/180Thermo/DHP PCM
Old 09-08-2008, 06:42 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Pulley Question!
isn't the MPS a quickchange? If so, you need to press it on, but it can be changed to a different size be simply removing some allen bolts.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-08-2008, 07:05 PM
Highbeamz Highbeamz is offline
Bang-on. MPS is Modular Pulley System. It presses onto the shaft and from there the pulley is held on by *usually* 5 allen head bolts. They are designed for easy change VS the time it takes to remove/move the fuse box, set up the puller, pull the pulley, press the pulley back on...instead, bolt on, bolt off, or vice versa.
2001 Pontiac Grand Prix GTP
14x,xxxkm's
Custom Cold Air Box w/ Airaid filter, Magnaflow Dual Tips, Quantum Tek 106 18" w/ Nexen N3000 rubber, Tinted Headlight Covers, Tinted Tails, Aeroforce Interceptor, 180* T-Stat, 2.5" ZZP Catted DP, Intense PCM, HID Conversion, F+R STB
Old 09-08-2008, 09:32 PM
BNaylor's Avatar
BNaylor BNaylor is offline
I've got 6. Thrasher MPS.
It takes less than 10 minutes.
Timeslip 08/12/06
AF Community Guidelines
Old 09-08-2008, 10:37 PM
Well the one I was looking at was 5, ZZP's.
I don't think it matters which vendor I go with for the MPS right? They all work the same...
14x,xxxkm's
Old 09-09-2008, 07:41 AM
BNaylor's Avatar
One half dozen or the other. Really makes no difference and yes they all work the same. It will be down to cost and which vendor you prefer to do business with.
Timeslip 08/12/06
