Old 09-07-2008, 11:29 PM
silverluminaZ34's Avatar
silverluminaZ34 silverluminaZ34 is offline
Post Aftermarket Pcm
I have 2002 Pontiac Grand Prix GTP.
i just purchased a aftermarket PCM and was wondering if theres any specific way to install the pcm without harming anything?
also when the reprogram the pcm, should i have them do a Cat Delete even though thats the one thing i havent got done yet?
2002 Pontiac GTP U-bend.resonator Delete/AL104s/180 Thermo/3.4 pulley, installing PCM
Old 09-08-2008, 06:40 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Aftermarket Pcm
What brand PCM? For installation just make sure the battery negative cable is disconnected and install it like you were doing a stock one. Do not over tighten the bolts that holds the 80 pin electrical connectors to the PCM. Also, it is recommended to get a crank variation learn (case learn) but installation should not preclude you from starting the engine up unless a crank sensor DTC is set.
Case learn must be done by the GM dealer with a Tech 2 scan tool unless you have a scanner capable of doing it.
Timeslip 08/12/06
AF Community Guidelines
Old 09-09-2008, 10:11 PM
Re: Aftermarket Pcm
Well i got the pcm in the mail today. Problem is, i installed the pcm, car started and ran A ok but the check engine light is on? not so sure i understand the crank variation learn is all about but, would the mechanic that installed all my mods be able to fix that?
Old 09-09-2008, 10:29 PM
BNaylor's Avatar
Re: Aftermarket Pcm
Yes. Just needs to scan it to see which odb-ii code it is. If P0336 or similar then the case learn must be done. The mechanic will need a scan tool capable of doing a case learn. Not too many can do it and most of us take it to a GM dealership where they run a Tech 2 scan tool. About a 10 minute procedure. Cost will vary from free to a range of $40-$80.
Also, if any of the DTCs are misfire either random or fixed P03XX the case learn should be done so the PCM can properly discriminate for false misfires.
Timeslip 08/12/06
Old 09-09-2008, 10:59 PM
Re: Aftermarket Pcm
Sounds good, Also will this harm my car at all? until i find out whos gonna fix it?
Old 09-10-2008, 01:40 PM
BNaylor's Avatar
Re: Aftermarket Pcm
I'd be speculating. If I were in a similar situation I would scan it at least and then make a determination whether it will harm anything after reviewing the DTC(s) but I realize you may not have the tools like an odb-ii scanner/scan tool like many of us have.
Timeslip 08/12/06
Old 09-10-2008, 06:10 PM
Exclamation Re: Aftermarket Pcm
Well i hooked a scanner up to it, the code i got was P1336. Anyone know what that code is from? let me know thanks
Old 09-10-2008, 06:48 PM
BNaylor's Avatar
Re: Aftermarket Pcm
Crank angle sensor learned error. It means a case learn is required since a new PCM module was installed. The matching tolerance in the crankshaft system needs to be learned.
Timeslip 08/12/06
