Old 09-07-2008, 04:45 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Switching tach cluster for std. cluster?
My daughter just bought a 95 GA SE with 4 cylinder. The speedo and odometer don't work. I'm going to change her instrument cluster which does not have the tach, but I'm wondering if I can just pop in a tachometer cluster from a 4 cylinder car without having to do any extra wiring? I don't have a manual yet for this car, is there an easy way to get to the instrument panel? My Mitchell book says the job takes about an hour IIRC. Thanks.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 09-07-2008, 05:47 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Switching tach cluster for std. cluster?
Im not sure if thiers a wire already ran for the tach or what color it would be.
If not it wouldnt be to difficult to run a wire from the ICM.
I'll check a wire diagram.
1999 Grand Am SS 3.4 OHV
Old 09-09-2008, 07:07 AM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Dash harness is different. If you are pulling a cluster from a wreck, grab the entire dash harness at the same time. It's a bit of work to do it, and don't forget to change the oil pressure switch with a sending unit for a pressure gauge.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 09-09-2008, 08:02 PM
Thanks. Does the dash harness only go to the firewall, or does it also go to the computer? I've pulled harnesses before, but that was on old pre-computer cars so it was relatively easy.
Old 09-12-2008, 06:21 PM
I do believe it connects on both sides of the dash. Should use the same ecm, just make sure it comes out of the same car ie same motor, transmission etc.
Yup, I own the suv.
