Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 09-07-2008, 04:04 PM
Mark.G Mark.G is offline
99 Civic Code p1457- Control Canister?
Hello , my friends 99 Civic has this p1457 code, Evap emission control system leak detected control canister system. I do not not know exactly what this means any help would be greatly appreciated. Thanks, Mark.
Old 09-23-2008, 12:59 AM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Re: 99 Civic Code p1457- Control Canister?
It means your EVAP system has leak (I believe it's a large leak code), it could be any of the EVAP components (purge valve, vent valve, loose hose...etc). It will trigger the check engine light again even if you somehow can resets it. It shouldn't affect your engine performance but it will cost you money overtime since your fuel vapor is leaking (gas is expensive). To fix it, you will need a smoke machine to find where the leak is at and that something you will probably need to let the repair shop to do.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
