98 Blazer wipers/fluid pump failure
I am having the same problem as a lot of posts concerning 98 Blazer wipers. For several months they worked intermittently and have finally died (wipers and wash fluid pump). I suspect the broken solder connection problem discussed in other posts. Now, I have never done much more than minor repairs and maintenance on cars. I would like to tackle this myself. The components seem pretty easily accessed under the hood and I can solder. (My mechanic already has made $600 this year off of me and still can't get my AC to hold freon. but thats another post...)
I have some nubie questions if someone could chime in... 1. What kinds of screws are those holding the plate on the wiper motor assembly? 2. What should I look for once I get the board out? 3. What parts can I just replace from an auto parts store. Any other advice would be much appreciated. Also, if anyone knows of a website where I could see some pictures or diagrams of what I will see once I dig in that would be tremendous. Thanks in advance, Rob |
Re: 98 Blazer wipers/fluid pump failure
1. Torx, t-25 if I remeber correctly
2. Look for cracked solder joints. If they are cracked you will see a fine line that circles the metal post that sticks through the solder. Hit them with a hot soldering iron and they should "reflow". 3. The plse board is avalable aftermarket, the motor is available aftermarket, and the motor / pulse board assembly is available aftermarket. This is the pulse board. Most often the solder joints near the black connector are the ones the crack. ![]() Red arrows point to the cracked joints on this board. ![]() Usually if this is the problem you can twist the black connector and get it to work or stop working.
Wow! Thanks so much! I am going to run out and buy the wrench and see what I can do.
I really appreciate the photos and solid advice -Rob |
My pleasure Rob!
