Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Interiors
Old 09-07-2008, 09:53 AM
vzfox vzfox is offline
a/c switch on dashboard
This is the first car I have owned that the a/c switch has two settings. The first setting lights the a/c switch up in a yellow/orange color. The second setting lights the a/c switch up in a green color.
What do the two seperate settings mean?
Right below that is also a fresh/recirc slider....In my vehicle history, the slider always controlled the "norm-fresh" and "max-recirc" a/c.
BTW......the a/c works fine, just curious on the seperate settings.
Old 09-08-2008, 09:31 PM
Re: a/c switch on dashboard
come on guys....i know at least some of you have a/c in your Eclipse and alot of you know what i'm talking about.....i just want to know why my a/c has two settings.
Old 09-08-2008, 09:54 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
The green light is when the ac is on. The orange is just the light from the switch that lights up when you turn the lights on.
The slider changes whether the air is pulled from the outside or recirculated. Not sure what your asking about that.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-09-2008, 01:46 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Eh that's actually wrong. The A/C is a dual push switch. I haven't had A/C in over a year now so I don't remember but when you push on to green, it's constant on. I believe when you push again and it's yellow, that's where it keeps a certain temp so it's not on all the time. I may be off on that one and couldn't find it in a quick search. So green constant on, orange turns on and off.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-09-2008, 05:00 PM
That's right....the push switch is a dual switch. The first time you press it, it goes in half way and the little light on it turns yellow'ish. The second time you press it, it goes in all the way and the little light on it turns green.
There are no temp numbers on the "cold-blue hot-red" turn dial, which leads me to believe it doesnt have a "temp setting control" for a/c.
I had no idea this question would turn out to be .
Old 09-09-2008, 05:55 PM
david-b's Avatar
Dave is THAT guy
Not a :bandhead: at all. That's how it is. Green is full blast, orange is a on/off setting. I don't know how exactly it works, but IIRC, the light will actually turn off or goto green after a while of the A/C being on.
And as long as the temperature knob is in the blue and the A/C is on... it'll blow cold.
75 Monte Carlo
Old 09-09-2008, 07:00 PM
Holset powered 420a
WTF??? My AC is either on or off. When the button is pushed its on and when the button is out its off. I have no idea about this dual switch shit, never even heard of it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-05-2008, 11:58 PM
Aces0vr8s's Avatar
Aces0vr8s Aces0vr8s is offline
Send a message via AIM to Aces0vr8s Send a message via Yahoo to Aces0vr8s
My air is Green or off also.
