Old 09-07-2008, 05:34 AM
whistlerXJR whistlerXJR is offline
92 Stealth non starter
Hi Guys,
I have just bought the above car as a non-runner...it is quite a rare car here in Spain and nobody knows anything about it
The story is:
Car had an erratic idle - revving up and dropping back again etc etc.
It was given to a "mechanic" to sort out....1.5 years later he vanished and the car never ran again .
The info I have is that he only removed the ECU and declared it to be the culprit.
It has been plugged in again and now won't start at all.
The car is being delivered tomorrow and just wondering if some of you guys can suggest what checks I might make to begin tracing the problems?
Thanks in advance,
david
Old 09-07-2008, 10:37 AM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
Re: 92 Stealth non starter
does it crank and not start or does it not crank at all or what other kind of noises does it make when u try to start it?
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 10-07-2008, 03:25 AM
Hi,
Just got round to looking at the problem.....The wiring to the ECU seems to have had some earth wires messed with. Also there is a red and white wire with a home fitted connector coming from one ECU multiplug - I cannot find anywhere that it was connected to.
Anyway......Switch on and all dash lights come on - turns to start position and lights stay same (no dimming ) and there are no clicks or other sounds from anywhere. just nottrying to crank at all.
any ideas where to start on this model?
Thanks guys,
D
Old 10-12-2008, 07:48 AM
Originally Posted by whistlerXJR
Hi,
Thanks guys,
D
what color wire in the ecu and which plug is the home fitted connector tapped into? and have u done any basic testing with the battery and starter at all? is ur car automatic or stick? maybe check the netural saftey switch.
