94 bonneville SSE
Hello
I'm having a heck of time figuring this one out. About 2 months ago my son says his bonne is running really rough, it doesn't seem to have much for power, and smells hot. The temp is in the normal temp range, and no check engine lights. The car has 200K + miles on it and we weren't sure when the plugs were changed last, so I changed the plugs and wires. It seemed to run a little better but not great. I then replaced the fuel filter think we still didn't know when that was changed. so I take it on a 10 mile drive on a state highway thinking my sons trips to school and back may have not given the engine a good work out. As I'm nearing home I get the feeling that the car is running way hotter then it should but the temp gauge is reading in the normnal range. In fact, I start smelling like I'm getting smoked like a ham. I pull into the driveway and look under the car and the catalytic converter is glowing red. Seeing that I figure hay it's the o2 sensor. I change that and It is still running like crude with a glowing cat. Any thoughts anyone? Head problem? I haven't done a compression test yet. Antig-freeze is holdin level. timing issue? how does one test that on a car without a distributer? Thanks for any help in advance Have a great weekend. Dale |
Re: 94 bonneville SSE
An excessively rich or lean condition or an engine misfire can cause this condition, if no misfire and the performance seems ok, I would do a full scan and look at fuel trims and sensor inputs. No way to change the timing, no distr.
Its not burning too lean OR too rich, its definitely burning too RICH:
Finally got my dream car: ![]() - but I can only afford one this big. |
sorry never posted the resolution to this problem.
It turned out that two of the coil packs had very weak spark. He had the two packs replaced and it has been running great. |
