Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 09-06-2008, 04:52 PM
chrissye41 chrissye41 is offline
Exclamation mountaineer
98 Mercury Mountaineer, hood "jammed" won't budge a bit, pulling hood release does absolutely NADA !..HELP !
Old 09-06-2008, 06:28 PM
rhandwor rhandwor is offline
Re: mountaineer
The vehicle needs to be on jack stands so you can get under it. I use a long screwdriver and go up from the bottom and move the latch lever. Then I usually go to the dealer and buy a new cable. Or you can get one at the junk yard. Normally the cable breaks or it just may need oiled properly.You may need someone to help you pull up when you move the lever.
Old 09-06-2008, 06:46 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: mountaineer
Can you tell if the cable for the hood release is still good? Sometimes there's just too much pressure against the hood latch and you can have someone push down firmly on the hood above the latch area while another person pulls out on the hood release. While the release is still pulled out, release the pressure on the hood and see if it pops up to the safety catch. If it does, then figure out who left their screwdriver/wrench/socket between the hood and and the fender lip. If that wasn't the issue, then clean and lubricate the hood latch with a dry lubricant.
If it's obvious that the cable is not making the connection between the release lever and the latch and the problem isn't just where the cable connects to the release lever, then the suggestions by rhandwor are probably your only option.
-Rod
