Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 09-06-2008, 03:54 PM
luxeryvic luxeryvic is offline
egr valve
i was reading somewhere that an egr valve that is stuck closed will cause increased combustion temperatures and lead to detonation,
isnt an egr valve that is stuck closed the same as no egr valve? so what happens if you do not have an egr valve like on performance manifolds?
this is just a curiousity question, thanks
Old 09-06-2008, 07:43 PM
boarder_punk's Avatar
boarder_punk boarder_punk is offline
Send a message via MSN to boarder_punk
Re: egr valve
This depends a lot on the vehicle, or specifically the generation. Newer vehicles (late model, OBD2-post '96) vehicles are computer controlled. Let's look at the purpose of the Exhaust Gas Recirculation Valve. The EGR does as its name implies, it recirculates exhaust gas containing unburned hydrocarbons (fuel) to reduce harmful emissions. Engines will run hotter with less gas (lean) and cooler with more gas (rich). The computer accounts for the EGR, without it the engine will essentially run leaner and hotter. The pcm would have to be reprogrammed or flashed to add fuel to make up for the lack of EGR. Most mechanical alterations to late model vehicles also require pcm reflashes in order to run properly.
I'm guessing that the performance manifolds you've seen without EGR ports are for older, non-computer controlled engines, carbureted engines. EGR valves on these engines always hindered performance partly because they were added on to old engine designs that weren't originally made for an EGR. These types of EGR valves were also completely mechanically controlled and weren't very accurate or efficient. They also couldn't account for carb setup and ignition timing like a late model computer controlled fuel-injected distributor-less ignition engine.
Old 09-06-2008, 07:52 PM
wafrederick wafrederick is offline
Banned
Re: egr valve
You can get an EGR gasket with a filter on it and Carquest is one that sells it.They can stick open due to a piece of carbon stuck holding it open
Old 09-06-2008, 07:54 PM
Banned
Re: egr valve
Some do not have an EGR valve from the factory and I have seen this on some GMs and some Chrysler products are this way too.
Old 09-07-2008, 09:48 AM
Re: egr valve
yeah thanks this helps alot, i was talking about first gen sbc thanks alot
