Old 09-05-2008, 02:03 PM
carrington312 carrington312 is offline
1995 c/k pickup: Engine studders and has coolant in oil. Blown head gasket?
My truck overheated and now studders when started and also has coolant in the oil. Im thinking maybe a blown head gasket? Im not sure .
Please help!
Old 09-05-2008, 03:28 PM
The_Mechanic_33's Avatar
The_Mechanic_33 The_Mechanic_33 is offline
Re: 1995 c/k pickup: Engine studders and has coolant in oil. Blown head gasket?
what size engine and how many miles on truck and how long u drive it while overheating? Sound like u are right could be intake but if lots of miles might as well bite the bullet and do the heads too.
Old 09-05-2008, 04:11 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
you can have coolant leaking OUTSIDE through the intake gasket, but coolant in oil - headgasket it is.
i'd even add that because it studders - you have coolant leaking into the cylinder/-s. it's not too bad of a job to do, just time taking.
if you were to do it DIY, don't foget to dry out every bolt hole so that there's no coolant left in it before re-assembling. of course, you could pull your oil pan off, drop pistons down through the pan, and replace tierod bearings and piston rings same time. hone walls. some elbow grease to clean combustion chambers, re-grind valves - hey, new engine!
Old 09-05-2008, 09:53 PM
wafrederick wafrederick is offline
Banned
Another case is if one cylinder head or both cylinder heads are cracked.A reman engine is cheaper than rebuilding with a better warranty.A rebuild for a stock 350 is about fifteen hundred in my area and a reman Jasper is twelve hundred with a 3 year, 100,000 mile warranty.
Old 09-05-2008, 10:15 PM
ukrkoz's Avatar
last time i did "in engine bay" rebuild my cost was $470 and 2 days of fairly intensive labor. if the motor as running good, no loss in mpg or smokes, indicating tight cylinder alls, standard piston rings and tierod bearings ill do.
so, you need honing tool, spring compressor tool rented, hand drill, headgasket, plenum gasket, exhaust manifold gaskets, maybe some minor ones here and there, piston rings, tierod bearings, hack might as ell do timing chain and all belts, hence you are "in there" anyway.
i doubt it'll cost even $500 oh, and lots of kerosin and nice wirebrush.
Old 09-08-2008, 09:38 AM
herkyhawki herkyhawki is offline
Originally Posted by ukrkoz
...., tierod bearings, ......
CONNECTING ROD BEARINGS
