Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-05-2008, 12:22 PM
spoovey703 spoovey703 is offline
larger tires
I am about to buy new tires for my stock 1998 chevy suburban. i am somewhat interested in buying slightly larger tires. What is the largest size i could buy that would fit without a lift and on 16 inch rims. also how will this effect my gas mileage?
Old 10-01-2008, 02:45 PM
east302 east302 is offline
Re: larger tires
Is it 4x4?
On those, you could go with 265/75/16 (which was a factory option over the 245/75) or the 285/75/16 without issue. A lot of people run 285 and you see plenty with the 265. I have 285/75 on a stock 1998 Z71.
The larger diameter will slightly affect your odometer. There are tire calculators online that you can see the differences. So if you're using that to figure mpg then your calculation will be off since the mileage is off.
On our 2003 Tahoe, I went from 245/75/16 to 265/75/16. They look so much better and I noticed maybe a 1/2 mpg loss. Hard to really tell...it could be due to driving habits, new tires having better resistance than the old bald ones, etc.
Not sure about two wheel drive tire sizes.
Old 10-02-2008, 11:41 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: larger tires
Ask the tire dealer if they can recalibrate the speedo/odo by either changing the VSS gear or by updating the ECM. There are also aftermarket tools that plug into the OBD-II port that allow you to adjust for the new tire size.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
