Old 09-04-2008, 09:23 PM
rscamaroboy89 rscamaroboy89 is offline
need to know what kind of amp
im buying two 12" rockford fosgate p2's 4 ohm subs.i need to know what amp should i buy that wont overheat and push these subs good,and i dont want to spend more than about $150 thanks.
my car 1998 grand prix gtp,borla catback exhaust,fwi,u-bend delete,resonator delete,
180 t-stat,zzp 1.0 pcm,zzp poly motor mounts,zzp shift kit,3 inch high flow cat,3 inch cutout.
not installed:zzp 3.4 mps,autolite 104's
next to order:headers with 3" downpipe
Old 09-04-2008, 09:30 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: need to know what kind of amp
150$ for a amp? lol.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 09-04-2008, 10:20 PM
there are quite a few for under $150 on sonicelectronix website.my friend has the same subs with a kenwood 1000watt amp and it hits hard but he had it overheat like 3 times and idk if i wanna go the same route.the amp he has was $130 but idk if its a good idea or not to buy one.and btw you didnt have to be rude. its a budget system im not rich
edited for language
Old 09-05-2008, 05:33 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
that is kinda cheap for a 1000 watt amp. There are plenty of amps in that power and price range to choose from but you typically get what you pay for. Usually overheating is caused by pushing the amp too hard, wrong speaker loads or poor ventilation.
Old 09-05-2008, 10:23 PM
theres a 600 watt amp from ma audio on there thats only $189.one of my friends has it pushing two 15's and its never overheated,so i might get that one.
Old 10-08-2008, 07:39 PM
JPontiac JPontiac is offline
Get a Sony XPLOD!
I have one and it is sweet!
Check out this site. It's Great!
http://www.andysautosport.com/
Old 10-10-2008, 04:34 PM
robkooL robkooL is offline
Banned
I have the same subs, you ABSOLUTELY have to get close to 500watts RMS. Over powering or under powering your subs can cause damage!
Old 10-10-2008, 05:28 PM
pre98zetec's Avatar
underpowering subs does not cause damage, clipping an underpowered amp causes damage.
if underpowering them causes damage you would cause damage every time you turn the volume down.
-Josh-
Old 10-10-2008, 05:59 PM
Audio Guy
Perhaps you should go talk to the heavy hitter SPL guys, they routinely put 4-5 times the rated power of the sub into it.
