Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 09-04-2008, 09:23 PM
casper.hughes casper.hughes is offline
no start need help plz
ok i have a 95 sebring lx with a 2.0 ltr dohc at transmission it has the following
no sprk
no fuel
no cel light
no battery light
no 8 volts at ckp sensor
no 8 volts at cmp sensor
the pcm is not grounding the asd relay i have two relays and two computers all grounds are good i have power from ign to pcm what could caus all of this plz help thank you
Old 09-13-2008, 09:35 PM
mustangmike351c mustangmike351c is offline
Re: no start need help plz
you need a PCM
Old 08-08-2012, 11:16 PM
rick8904 rick8904 is offline
check your 20 amp fuses underhood ,it should be your # 8 fuse. mine was. a $125.00 later all it was is a 50 cent fuse.That fuse is to your starter relay fuse next to it.
