Go Back   Automotive Forums Car Chat > Cadillac > Fleetwood
Old 09-04-2008, 02:46 PM
bears81297 bears81297 is offline
Unhappy 1991 fleetwood
my car will start but wont stay running relays are good think it might be something inthewiring need help please
Old 09-04-2008, 02:58 PM
maxwedge maxwedge is offline
A990 racer
Re: 1991 fleetwood
Welcome to AF, boy that is vague, when it dies can we assume that it won't restart, have you done the basics, check the fuel pressure for starters?
Old 04-22-2010, 07:17 AM
samak samak is offline
Re: 1991 fleetwood
I'm presuming the B23 engine? Have you checked fuel pressure valve located on the inlet manifold, are your plugs getting soaked in fuel?
If not try looking at the Fuel relay in the block situated behind the ash tray below the Radio.
It might be easier for you to access this by taking out the coin tray, flip the cover plate off the cigar lighter it will reveal 2 screws, take that out and the tray then you'll see a whole lot more relays.
There are different types/colours I'm guessing your could be Blue but there are white ones too.Try Jiggling them carefully then crank the engine if it runs but poorly replace.
You must replace with correct one even if it is Blue some have Copper Lugs others steel and they are different.
Good Luck!
[Unauthorized link removed by Moderator]
Old 04-22-2010, 03:18 PM
A990 racer
Re: 1991 fleetwood
Please look at the dates before posting, this is 1.7 years old and inactive, thanks.
