Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 09-04-2008, 02:19 PM
woodturner2 woodturner2 is offline
Question 2001 Monte Carlo not charging
My Monte Carlo is not charging i had the alternator checked and it is good. I was told the computer controls it but i dont know which one controls it the BCM or the PCM?
Old 09-04-2008, 02:26 PM
inafogg inafogg is offline
Re: 2001 Monte Carlo not charging
hello,if alternator is good check to make sure you are getting 12v to alt.
look for the heavy red wire going to post on alt should be 12v there.
Old 09-04-2008, 03:00 PM
Thanks inafogg i checked the red wire there is no power there. Do you have any idea what to check next?
Old 09-04-2008, 03:16 PM
not real sure without wiring diagram but i think power comes through a fusible link at starter again not sure.you can also look at fuses under hood & fuse box.what engine & trim package do u have i'll see if i can find wire diagram
Old 09-04-2008, 03:22 PM
Thanks, it is a monte carlo SS with 3.8.
Old 09-04-2008, 03:37 PM
here you go wood
http://arrc.epnet.com.oh0049.oplin.o...LET±MONTE CARLO&yr=2001&ff=va133447.pdf
a 3.8l should be the same but this is for a 01 monte 3.4l the only 1 that is listed
Old 09-04-2008, 03:48 PM
Smile Re: 2001 Monte Carlo not charging
Thanks a lot for the help I found the problem the wire was off at the starter!
Old 09-04-2008, 05:10 PM
good, glad it ended up being a easy/cheap fix
