Old 09-03-2008, 08:53 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
Clutch upgrade help..
ok well heres the deal, im going to be upgrading my clutch in about a month or so to a spec stage 3 clutch. but what i want to know is for you ppl that have done a clutch already, do i need any gaskets or seals of any kind? and basicly i just need to unbolt tranny mount and drop the tranny subframe and take off the Tcase rite? pretty straight forword? im gonna do the rear main seal while im in there for sure. but what gaskets do i need so i can order them b4 hand. thanks.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 09-04-2008, 03:56 AM
DCIV's Avatar
DCIV DCIV is offline
Re: Clutch upgrade help..
well your going to need to drop the pan if your going to do the rear main seal, so you will need the gaskets for the oil return lines and plenty of RTV for the oil pan. Lots of fluid for the tranny and new fluid for the tcase. You will want to replace the TOB and make sure to use plenty of grease on the pivet point. Get your flywheel two steped, and clean the face of it and the clutch disk with carb cleaner before install. Make sure you torque everything down on the pressure plate properly and when you put the tranny back make sure to not let the the tranny hang on the clutch as it will throw it out of center. I think thats just about all I can think of at the moment. Good luck.
Coop
Old 09-04-2008, 09:32 AM
when i do the rear main seal should i just replace the full assembly or just the seal.? and is there a gasket behind the assembly or just rtv?
Old 09-04-2008, 11:42 AM
Stealthee's Avatar
Stealthee Stealthee is online now
Your worst nightmare
Coop
You dont have to drop the oil pan. I have replaced a few rear mains and never once dropped the oil pan and never once had an issue for doing it the way I did it.
As for dropping the trans it is pretty striaghtforward. I can have mine on the ground fairly quickly.
Old 09-06-2008, 06:26 AM
DCIV's Avatar
Really? I guess I just always drop the pan while I am right there.....never really tried not to.
Coop
Old 09-06-2008, 08:51 AM
Stealthee's Avatar
Yeah you are going thru the process of removing the whole housing. I've never felt the need to do it that way and just remove the seal and seat the new seal.
Old 09-09-2008, 02:06 PM
DCIV's Avatar
I am about to go replace my rear main seal and I am just going to replace the whole thing. There is suppost to be a "special tool" I am sure I could make something work...aka the old seal on top of the new one...but I just bought the one already installed so I guess I am droping my pan.
Coop
Old 09-09-2008, 02:34 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Yeah I have never pulled the pan to replace the rear main seal.
Jason
Old 09-09-2008, 04:48 PM
Stealthee's Avatar
Coop
Yeah if you got the whole thing you may as well do it.
Old 09-10-2008, 08:12 AM
Girly VR-4 Girly VR-4 is offline
stay away from spec clutches. They are nothing but problems.
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 09-10-2008, 09:24 AM
jason_bet's Avatar
What are you talking about? Have you honestly ever had one with problems? I have sold a shit load of spec clutches and I havn't ever had one complaint.. not one..
What issues have you had with yours? What clutch from spec was it? and what would you go with?
Jason
Old 09-10-2008, 11:46 AM
Stealthee's Avatar
Check out 3si. People are having issues with spec clutches all the time,
Old 09-10-2008, 04:41 PM
jason_bet's Avatar
I have never seen a thread on there.. not saying there isn't but I honestly havn't seen any. And like I said.. I havn't ever had one come back or had anyone say any thing negitive about it..
Jason
Old 09-11-2008, 02:27 PM
Jason
The springs have a tendency to explode out of the clutch disk. We've had quite a few come through the shop with this problem. And that is one of the major reasons why we refuse to even sell them.
www.3swarehouse.com
Old 09-11-2008, 02:51 PM
jason_bet's Avatar
Really?? Thats why I don't sell South Bend.. I sold 3 when I first started selling them and all 3 came back for that reason! I haven't ever had one come back from spec..
Jason
