Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 09-03-2008, 09:54 AM
tfsmith2 tfsmith2 is offline
Remove Power Steering from 1997 Olds 88
In the process of replacing my water pump, one of the water pump mounting screws backs up into the power steering pulley. In an attempt to get the screw out, I am not sure whether to remove the power steering by removing its mounting bolts, which despite having a Haynes manuel schematic I am having difficulty finding, or can the power steering pulley be removed from under the hood without first removing the power steering system (the power steering pulley puller that I rented to try and do this would not fit). What is the best way to procede? To remove the entire power steering system what other components, if any, need to be removed first. My knowledge of cars is very limited but I am able to follow suggestions.
Thanks - Taylor
Old 09-03-2008, 02:17 PM
maxwedge maxwedge is offline
A990 racer
Re: Remove Power Steering from 1997 Olds 88
Welcome to AF. Loosen the pump and move it forward, you will be able to access the bolt.
