Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-03-2008, 09:43 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
A/F ratio and ignition timing
I just started running ignition timing with MS and built a pretty good spark map. Im running 16psi on the 14b and had a good bit of knock around 5k and 6k. My AFs are in the mid to low 11s under boost. I set all timing advance to 14 degrees when above 125kpa and over 4k rpms and all knock went away. My question is what kind of timing advance do most people see under boost? I thought I should set advance to 15-16 degrees around 5k which is peak tq and start advancing after that to around 18 degrees at redline.
I plan on slowly start advancing timing till I start seeing knock then retard it 1 degree but I would at least like to have an idea of where I should be in boost.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-03-2008, 11:50 AM
steviek's Avatar
steviek steviek is offline
Re: A/F ratio and ignition timing
yea thats right on man. Most people make high teens timing advance on pump gas near redline. Obviously more if you can run higher octane. your numbers look good!
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 09-03-2008, 02:39 PM
Holset powered 420a
so how much does timing effect hp. Say I can only run 16degrees of timing max around 16psi with out knock. Would it be better to run higher boost with lower timing or say drop the boost to 14psi and run 18-19 degrees of timing. I know most of this is trial and error and see what works best.
Steviek - What does your timing look like at full boost from 4k - redline?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-03-2008, 02:42 PM
Holset powered 420a
Also if I lower the AF to say more around 11.0 would I be able to run another 1-2 degrees? And would this be better than running a little leaner as far as HP and running the motor safely.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-03-2008, 03:51 PM
steviek's Avatar
Typically more power can be made from boost and timing than extra lean conditions yes.
4688 rpm 11.2d
5081 13.3
5531 14.7 peak ve begins to end
5981 18.6
6510 19
7009 18.3
as for what is better boost or timing. Boost is until your compressor efficiency starts to drop off. When that happens then it would be far more productive to cease to raise boost and begin increasing timing (provided no knock) only a compressor effieciency chart can tell you when that is.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 09-03-2008, 04:25 PM
steviek's Avatar
flow map
Raw map
Reference Site
http://www.stealth316.com/2-3s-compflowmaps.htm
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 09-03-2008, 05:43 PM
Holset powered 420a
So on the 14b anything over 18psi is no good basically. So I need to raise the boost a tiny bit and get the AF in the low 11s or so and then slowly increase timing until it knocks. And thats all the power the motor will push on this turbo.
Here is my spark map right now. I added a little timing around 6k and have yet to test for knock. I rarely see that part of the map anyways. It seems that you run real low timing around 4k or so. I always thought you should start around 20 or so at 3k, drop to 15 around 5k and increase a little more toward redline. Check out my map and let me know what you guys think. I hit about 16psi @ 3500rpms.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-04-2008, 11:08 AM
steviek's Avatar
Ya anything under 4500rpm i don't even really bother with because I don't make any power there anyways. Your timing chart looks pretty solid for a base tune but it really means nothing without knock being registered at the smae time.
Ilike the colour coordination showing you what is aggressive (red) and safe (green) I think that feature helps a lot cause you whant to see smooth colour transitions not a red bloch beside a green one type of thing. I like MS.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 09-04-2008, 12:55 PM
Holset powered 420a
If I run threw the gears all at full boost I can keep the turbo spooled at low rpms so Im going to lower the timing in the high boost/low rpm range so if I happen to hit that point some it wont be such a jump in timing when it goes down to 15degrees or so. It needs a little more work but the car runs good for now. I want to hit up the track next week so I may do some more tuning this week. Im going to run a pretty safe tune so no chance of knock.
It is a real pain for MS to log knock. And even when you get it working it phantom knock is still a problem. I tune for knock by listening to the motor. I have a stethyscope(sp) type system I am using and its sweet. You can hear any bit of knock but you just have to remember at what rpm range it was at.
MS is pretty f*ckin sweet. I wish I would have gone to in a long time ago.
Steviek - What are your intake temps at under boost? After a few hard runs mine are around 140F. Temps here are around 90-95F. I would like to get some logs done at night to see how much the temps drop and how that effects knock and AF ratios.
A little off topic, but should I be concerned with heat soak on the intercooler at the track. I was planning on taking a bottle of ice water and soaking the intercooler between runs with it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-04-2008, 01:34 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
I would love to get MS at some point, but I don't know if I'll ever get to that point in this build.
If your temps down there are mid 90s, I would say heat soak would be a problem. It'll probably be sitting out in the sun for a while right? Never hurts to ice it down.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-04-2008, 02:10 PM
steviek's Avatar
Now I don't know what ambient temperatures were this day but my intake temps are pretty good relative to other people. Especially under WOT. I have my intake dam which keeps the engine heat away and if I'm racing I take out my passenger light which basically rams in ambient temp air. o On the run where I gave you the timing numbers I did not have my light out and my intake temps were as low as 83f with a max of 97 right after a shift.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 09-04-2008, 08:46 PM
kjewer1 kjewer1 is offline
AF - Advisor
Compressor efficiency doesn't mean anything with good intercooling. Just food for thought. As far as the timing goes, that seems too high to me at peak cylinder pressure. The 2g timing map is a great place to start, you should be able to find it in the DSMlink documentation. I build it into my AEM cal files as a starting point, even on the RWD.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-08-2008, 09:37 AM
Holset powered 420a
Thanks for the info Kevin. I would actually like to get a hold of a 4g63 timing map but cant see to find one online. Maybe someone with link could post up a screen shot on theirs?
Kevin what should my timing be at peak pressure? 13degrees, 12degrees? 14 degrees seems to run with no knock right now but maybe Im on the verge of getting knock and to run 13 or so may be a little safer? Is that what you were getting at?
Also how much more HP do you get from advancing the timing. I wouldnt mind runing a little less to be safer if I was only going to loose like 5-10hp. But I dont want to lose 30.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-08-2008, 10:55 AM
steviek's Avatar
http://jeffgst.com/id20.html
Yea you won't lose 30hp with one degree of timing. BUt if you're not knocking why bother?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 09-08-2008, 12:40 PM
Holset powered 420a
Awesome link steviek. Thanks
Im going to build a new ignition table that is pretty close to the stock 2g one and see how the car runs with each map.
98 Eclipse GS Turbo
2001 BMW 325i - DD
