Old 09-02-2008, 11:11 PM
mabowens mabowens is offline
94 Chevy Air Conditioner Problems
My A/C stopped working. The compressor stays on at idle but kicks out when accelerating. The high pressure line freezes up coming out of the condenser all the way to the evaporator. High side pressure holds at 225 and low pressure side holds at 30. Any ideas of what the problem is? Thanks
Old 09-03-2008, 10:09 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 94 Chevy Air Conditioner Problems
Need pressure readings at idle and at 2K rpm.
MT
Old 09-03-2008, 11:32 PM
jyount jyount is offline
Sounds like you have a restriction in the line from the condensor to the evaporator, or in the condensor itself. The freezing up is from a pressure drop. Temperature of the system at certain points is the best a\c diagnostic there is. Usually when there is trash, restrictions in the lines, especially before the accumulator, your compressor is coming apart.
Old 09-18-2008, 03:28 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
What is freezing is water that has gotten into the system and is the result of the dessicant in the accumulator that has broken down and no longer able to remove water from the refrigerant. Pieces of the dessicant may also be clogging the lines.
As MT suggests...we need pressures at both rpms. If it rises at the higher rpm, then it may be cutting out due to the over pressure switch, but should cycle on/off as the pressure drops.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-20-2008, 02:59 PM
j cAT j cAT is offline
the pressures at idle look too low....at about 1200rpm the low side pressures may drop so low that the compressor is commanded to turn off...
if this is the case add more refrigerent to the system...45psi low and 325psi high at 1200-1800rpm...@air temp of 80-85 degrees with the fan to max windows open...
If you had air in the system the low side would be low and the high side would be very high , much higher than your readings...
