Go Back   Automotive Forums Car Chat > Ford > Super Duty
Old 09-02-2008, 09:16 PM
alshane alshane is offline
2000 f250 overdrive on/off switch
the overdrive on/off switch on my f250 don't work. i replaced the button with a new one and still no results. what else could it be?
Old 09-05-2008, 12:30 PM
rhandwor rhandwor is offline
Re: 2000 f250 overdrive on/off switch
AMCO transmission shop will pull transmission codes free. I would check for codes first. Auto Zone and Advance Auto will pull codes free also. I would check that all plugs on the transmission are plugged in. Apparently the torque converter isn't locking in is that correct.
Old 09-17-2008, 09:33 PM
i talked to a few transmission guys and a ford mechanic and two of the three said the same thing. Fords are notorious for a wire losing connection inside the shifter itself. they said the quickest option was to just replace the whole shifter (takes about 20 minutes and cost just under $100.00). another option is to try and find the wire that is losing connection and re solder it.
Old 09-18-2008, 03:27 AM
Selectron Selectron is offline
I'm not familiar with your vehicle, but I'd suggest you take a look at this thread for a Windstar with the same problem. After much discussion, the problem turned out to be a broken wire, just as you described, and if you skip down to the last post in the thread, there's a link to a photo of that wire.
Your switch is wired in an almost identical fashion to the Windstar. Here's the wiring diagram for the F250 Overdrive Cancel Switch, and it works like so: from fuse 19 (10A, Central Junction Box) a red/yellow wire applies 12V to the switch input terminal and the high side of the indicator lamp. When the switch is closed, a tan/white wire feeds that voltage forward to pin 29 of the PCM. If conditions are right, then pin 12 of the PCM will ground the low side of the lamp via the white/light green wire, and the lamp will then illuminate.
Notice though that at the point where those three wires connect to the switch, it says 'NCA' - that's 'No Colour Available', so the wire colours immediately adjacent to the switch are not known. Judging by that Windstar photo though, you'll have no problem identifying them, and it looks like he had to cut that short section of the harness open to get a good look at them and find the broken one.
Old 02-02-2009, 07:32 PM
ronboatplane ronboatplane is offline
Did you ever get a conclusion? I have same problem and I have been told on the forum that it may be a shifter problem which is common to
Fords. Playing around with system I can sometimes, seldom though, get the system and OD button to work. This is usually when I have been driving the truck for a while and move in and out of drive until it starts working normal. So maybe if I knew where the shifter was I could learn more. I am guessing that the shifter, whereever it is, is not supplying power that it is supposed to provide even though the unit is in drive. So what is a shifter?
Old 02-02-2009, 09:43 PM
Thank you all. you guys put me on the right track and the problem is solved. I took the easy route and just replaced the whole gear shifter. It took about 45 minutes and not as much as you would think had to be removed. thanks again
Old 02-02-2009, 09:46 PM
the "shifter" being referred to is the gear selecter shifter where the o.d. push button is located. I just bought the whole assembly from ford and took off the cover around the steering column and replaced the whole unit. It took about 45 minutes and the problem is fixed.
Old 02-03-2009, 03:06 AM
How much for the shifter?
Old 02-03-2009, 08:42 PM
Smile Re: 2000 f250 overdrive on/off switch
Thanks everyone. I went out to Ford and bought a shifter as well and based on advice here I probably won't be posting on this problem again. Cost from Ford is $65 retail and includes a new shifter arm, boot, OD button and wiring with plug. I was into the steering column plastic once before so your estimate of 45 min seems about riight. It does take me an extra 15 min to disconnect the two batteries in the diesel as a safety to prevent air bag deployment. So everyone's previous experience was invaluable and much appreciated. Thanks again.
Yes, that did it. The shifter wiring was internally defective as per previous report of a similar problem.
To recap: If your having trouble with your OD not working and button is sometimes ineffective you probably have the same situation. Replace the shifter as described prevously. Disconnect batteries, remove the three philips screws on the bottom plastic, remove the tillt lever with a small crescent wrench, set asside the bottom plastic, remove the lock tumbler now accesable with bottom plastic removed, this is accomplished with the with key in and switch in on postition. Release tumbler by pushing in locking ball at bottom with a very small philips. This allows you to pull out tumbler with key in and tumbler in run postion. You now have access to the top plastic. Next locate and disconnect the four conductor small plug coming from the OD button in the old shift lever. Lift out the hood of the old assembly you are replacing. Last of the removing steps is pulling the pin straight upward so you can remove the gear lever and associated parts. Now the easy part. Just reassemble the same way you took it apart.
Now that I have done one it probaly takes would take about 15 minutes but the first one took me an hour.
Old 12-13-2009, 08:33 PM
pwinship pwinship is offline
Just came across this thread and have a question:
I have a 2003 F350. When I push the overdrive (tow/haul) button, it lights up, but I notice no other difference. Am I supposed to feel the truck come out of overdrive?
Sorry to sound stupid, but this is my first Ford.
Old 12-17-2009, 12:56 AM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
If its in O/d you should feel it kick out, yes.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 12-17-2009, 12:48 PM
Thanks for the reply.
I tried it again and it does kick out. Didn't feel it last time, it was a lot more subtle about it than I expected. Still learning a lot about this truck. So far, I've had it only 2 weeks. And I like it.
Old 12-17-2009, 11:03 PM
Good deal, What motors in it?
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 12-24-2009, 03:06 PM
6.0 powerstroke
Old 12-24-2009, 03:18 PM
6.0 powerstroke
Great you should love it! Have fun.
'95 Ford F-150
Ford Racing Pride
General Motors who?
