Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-02-2008, 08:51 PM
ARK51294 ARK51294 is offline
Differential removal
98 1500 4x4 I have evrything to my knowledge dissconnected on the rear. Axles are hanging out the sides but where the Ring is connected it wont pull out... Shouldnt it slide out or am I missing something
Old 09-03-2008, 10:02 AM
angus10 angus10 is offline
Re: Differential removal
Did you remove the carrier bearing caps? If you did ,you might have to rent a case spreader. If you carefully pry on it , it might drop out. Be careful.
If it does come out you still might have a prob getting it back in without the spreader.
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
Old 09-03-2008, 01:40 PM
CanukGMC CanukGMC is offline
The carrier in my Jeep was stubborn to come out (sign of a nice tight fit at least). Get some kind of cushions (old pillows or something), maybe even a friend below the diff to catch the guts if it pops out suddenly and carefully put something soft around the carrier to pull on (towel, CLEAN tow strap, etc) and try that. I did one once and had to put both feet on the axle tubes and pulled hard. You -need- to have someone or something to catch it when it falls or you will do damage to it (it is not meant to be dirty or dropped). To put it back in I used a block of soft wood (fresh pine 2x4 works) and a rubber mallet and tapped the carrier back it a little on each side at a time so it went in straight.
Old 09-12-2008, 05:22 PM
Yeah nice tight fit...... Mine is real tight..... I just wrapped a chain aound it hooked it to a tow bar on a passport and pulled (it didnt budge) It moved the truck but not the carrier.....
Old 09-12-2008, 07:06 PM
wafrederick wafrederick is offline
Banned
You need a special tool to set that rear end up,it is a long 5/8" bar with a bigger hex on it.Miller tool whom makes Chrysler's special tools sells it.Do not attempt setting it up without the special tool.
Old 09-13-2008, 06:29 PM
What does it do/for?
Old 09-13-2008, 09:08 PM
Banned
The tool screw in two screw ins which I call nuts.Pull both caps and you will see them,they have threads in them.Check the backlash before pulling apart with a dial indicator and write that down.
Old 09-14-2008, 01:50 PM
is that what is not letting me get this carrier out?
Old 09-20-2008, 11:02 AM
You should only have to remove the caps for it to come. BTW, did you get it out?
98 Ram 1500 4x4
Old 09-25-2008, 05:17 PM
Nope havent got it out... going to take it to a dealer....
I am assuming I have a 3:55 ratio if I put a 3:90 or more in it will it be stronger for towing and such (its a daily driver as well)
Old 09-26-2008, 03:28 AM
You did remove the 2 bearing caps correct? And anything is better than 3:55's. You know you have to change the front gears too if you do the back.
98 Ram 1500 4x4
Old 09-26-2008, 05:57 PM
yeah caps. where removed
