Old 09-02-2008, 08:28 PM
Pwnedheadnad Pwnedheadnad is offline
clicking sound when accelerating in 2wd & 4wd
i have a 1993 jeep cherokee 4wd, 5 speed, 4.0 engine. when im in 2wd or 4hi or 4lo and i take off fast there is a clicking sound coming from either the trans, transfer-case, or front end. it only clicks a few times then stops.
Old 09-04-2008, 06:51 PM
soldierp89's Avatar
soldierp89 soldierp89 is offline
Re: clicking sound when accelerating in 2wd & 4wd
U JOINTS!. had the same problem with my 94. under heavy acceleration was the only time. "thought" my ujoints were fine but when i did my lift kit the rear driveshaft u joint that goes to the differention pracitcally fell apart so. make sure that you take a look at those and make sure there is NO movement. if there is, replace. theyre only like 15 bucks from napa and easier to change than the front axle u joints.
89' YJ / 95' YJ / 94' XJ
4.2 L I6 / 2.5 L I4 / 4.0 L I6 HO
5 Spd. AX 15 / 5 Spd. AX 5 / AW4 3 Spd. W/ OD
4" Rough Country / 4" Pro Comp
Mickey Thompson 33/11.50/R16
BFG Mud Terrain 33/12.50/R15
Old 09-04-2008, 09:20 PM
thanks for the idea but i just check my ujoints and they are solid, no rust or movement. any other ideas?
Old 09-05-2008, 03:37 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Solid with no rust or movement was how mine were before I replaced them....and my clicking went away. The inside is the important part and a visual inspection won't see that.
How many miles do you have? If it's more than 90K and you haven't replaced the U joints, then I agree 100% with soldierp89.
The only other thing I can think of that clicks under acceleration would be a broken wheel stud.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-06-2008, 03:04 PM
my jeep has 135,000 miles on it and the guy i bought it from was not a mechanic of any sort. are you saying both my front and rear ujoints are bad?
Old 09-07-2008, 05:22 AM
Nope, not saying both are. It's likely it's just the rear, since most 4wd vehicles aren't in 4wd all the time.
IMO, replace the rears and then reevaluate.
Old 09-07-2008, 07:27 PM
i had something weird happen today. i was driving and i smelt a bruning smell and when i braked the jeep would veer off to the left. i just put need pads and new rotors on both front wheels. then i shut off the car for a while. then later fired it up and drove 8 miles without a problem. what could that be?
thanks
Old 09-18-2008, 01:38 AM
gatoratoy227 gatoratoy227 is offline
possibly one of the calipers wasn't reinstalled correctly i know it sounds far-fetched but i've seen it before the caliper overheated then by some overwhelmingly confusing way that is completely beyond me it managed to realign it self
NO! ,we can't stop here, this is bat country. Raoul Duke
