Old 09-02-2008, 01:07 PM
86Sebring 86Sebring is offline
Voyager bad odor from vents
I just bought a 2000 grand Voyager, we are very happy with the minivan, it gets pretty good mileage, runs quit and smooth. The problem is a bad odor coming from the vents, if I turn on the AC or heating.
I guess it is dirty evaporator or blocked drain.
Is there an easy way to access the evap, or maybe a trick to correct the problem w/o removing the evap?
thanks
Old 09-02-2008, 02:39 PM
webbch webbch is offline
Re: Voyager bad odor from vents
You obviously have an idea of what your up against - taking out the evaporator requires dropping the dash. As far as "tricks", I've not tried it on these vans, but IF you can gain some small access to the evap through one of the mode doors, by removing the blower, or ???, then a "trick" is to use some plumbing fittings to make an adapter for your garden hose down to 1/8" or 1/4" pipe to form a miniature "pressure blaster". Try shooting some bleach water in through whatever access port you can reach. You'll want to cover the carpet obviously.
Like I said, I haven't tried it myself, I've just heard of this trick being used on another vehicle and it sounded kind of slick for evaps that are a bear to get out. That said, if you DO end up removing the evap, I'd sure just replace the darn thing to make sure I didn't have to drop the dash again in the near future.
Chad
2003 Honda Odyssey EXL (3.5L)
2002 Volvo V70 X/C
1990 Chevy Silverado K2500 (5.7L TBI)
Old 09-02-2008, 08:13 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
I remember a few years back seeing a product on a car show on TV that was something like a spray can detergent with a small straw (like a can of WD-40) that you'll insert the straw thru the drain hose fort he evaporator and deplete the can in there.
The detergent will foam up inside and clean, deodorize and freshen up the evap, then the foam dissipates and flows as a liquid out thru the drain tube. In theory sounds good, I've never tried it but it's worth a try.
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 09-03-2008, 06:04 PM
Rama Rama is offline
I just had the same thing with my 97 voyager. I found out that the drain was blocked. Took it off and unplugged it, then blew some compressed air in the opening. Then I read somewhere in these forums someone said turn your blower on high and spray lysol disinfectant into the intake vent below the wipers. My smell is now gone.
