Go Back   Automotive Forums Car Chat > Cars in General
Old 09-02-2008, 03:25 AM
wade623's Avatar
wade623 wade623 is offline
injector/engine cleaner
i dont think this is a fuel economy issue but is ther any thing worth using that works without having to use it all the time
__________________________________
Practice makes less imperfections.
Old 09-02-2008, 06:04 PM
C man C man is offline
Re: injector/engine cleaner
Who knows. I have yet to come across a fuel injector cleaner where there was a noticeable differences except for a better start. I guess if you properly maintain your vehicle you wouldn't noticed a big difference anyway because the fuel system is already in good shape if you keep maintenance up. Currently I'm running Gumout complete fuel system cleaner thru my car. I paid $6+ for it and I don't see any big difference. The only reason I put it in is because I haven't but any fuel injector cleaner in my car for at lest for or five months and it eases my mind.
95' PARK AVENUE 168,000 MILES
Warning : Listen at your own discretion
Old 09-02-2008, 07:43 PM
wade623's Avatar
what about as far as carbon build up on pistons ans valves
by the way what is seafoam
Old 09-03-2008, 04:03 PM
I have no idea but I have used it as fuel injector cleaner before. Same as usual no noticeable difference except maybe at start up. But the same can that you can use as a fuel injector cleaner, can be used to clean out the engine when doing an oil change so it has to be some tuff stuff. I've heard its good but not really sure what it contains. But if it is suppose to clean the engine out I'm sure it does some cleaning when using it as fuel injector cleaner.
Old 09-05-2008, 06:08 AM
wade623's Avatar
i looked it up and it seems pretty good i want to try it to see if it helps a rough idle
Old 01-09-2009, 10:09 AM
ahoier ahoier is offline
I don't know if they actually help or not....since well, as pointed out in the thread, if you keep your car in decent working order, you shouldn't have problems.
But previously I added the STP "Complete System" cleaner and clocked it, it's coming about due for another treatment, but I don't notice any difference, so I think I'm going to try the "SuperTech" Fuel Injector and Carburetor cleaner, the MSDS contents looks similar, so I don't think it can be that bad.
I've been adding STP "Gas Treatment" usually every (or every other) fill up, so it's not like a got an overly dirty system anyways. Which is why I don't know if it really works or not, but I've been applying it more for "prevention" of problems since I do tend to "mix" gas brands (don't stick with 1 brand, but go for the cheapest station...).
I know SuperTech has a 2500 mile treatment and it's a lot cheaper than the STP/GumOut and the MSDS contents look similar.
I still average about 300 miles per tank, no matter how I look at it - so I'm guessing my injectors are fairly clean
Old 01-09-2009, 11:18 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines:
POSTING IN CLOSED OR OUTDATED THREADS:
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
