Old 09-01-2008, 10:46 PM
Gm crazzy Gm crazzy is offline
Send a message via Yahoo to Gm crazzy
steering niose
I have a 1999 GMC SLT 4.3 L. Its makeing a real bad creaking noise when I turn the wheel both left and right. I have the fluid on full and its not burned out, also theres no viberation or change in drive or ride its still as smooth as the day I bought it.
Old 09-16-2008, 01:23 AM
gatoratoy227 gatoratoy227 is offline
Re: steering niose
sounds like a ball joint or tie rod if there are grease fittings on them grease them if its the same creaking noise i think it is my buddy's taurus had the same thing turned out to be a bad lower ball joint there are roughly 10 diffrent areas that could be at fault upper, lower ball joints,
outer tie rods, inner tie rods, drag link, idler arms, and pitman arm
NO! ,we can't stop here, this is bat country. Raoul Duke
Old 09-16-2008, 02:05 AM
Re: steering niose
grease every thing under the truck that has a zerk fitting you will have roughly 10 diffrent places inner/ outter tie rods, upper/lower ball joints, pitman arm and idler arm
