Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 09-01-2008, 05:59 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
Idle Air Control
I have a 96 Tracker 4X4 with the 1.6 16 valve motor. I am haveing trouble finding the idle air control valve. I have a Chiltons manuel and it says it is on the right side of the throttle body and I still can't find it. The only thing I can find near the throttle body is the throttle position sensor. I have to be looking right over it. Can anyone tell me where this valve is? Any help would be appreciated.
Old 09-26-2008, 02:46 PM
ranger88den ranger88den is offline
Re: Idle Air Control
It's on the driver's side of the intake manifold in front of the throttle body. It has an electric connection, coolant line and, I think, a vacuum line.
Old 09-26-2008, 09:49 PM
Scotty89's Avatar
Thanks for the help. I did find it, the coolant lines threw me off. To me it doesn't make since to have coolant lines tied in with the idle air control.
Old 09-27-2008, 07:49 AM
Must work like a choke adjusting idle to temperature. I'm having a low idle issue when cold and a very knowledgeable fellow at Suzuki-Forums (jtgh) suggested this could be the problem. Good luck
Old 09-27-2008, 08:30 AM
Scotty89's Avatar
The problem with my car i found out is the throttle postion sensor. Not the idle air contol motor.
Old 09-29-2008, 05:59 AM
Good for you, hope you got it fixed.
Old 09-29-2008, 05:48 PM
Scotty89's Avatar
Well the TP sensor is about 200 dollars. So i have it unhooked until i can replace it. I'm starting school soon and dont really have the money for something like that.
