| Off-Topic Talk about anything other than cars. |
Hey all;
As I've been tuning I've been watching what's going on with the WBO2 and everything and noticing some things. When you let off the gas, the car runs lean because you're going from giving fuel to nearly none. But if you throw it out of gear and let idle up to a light or whatever, AFR is at 14.7. Rolling up in gear, AFR sits at --- since it's way off the board. So, would leave the gear in gear (either downshifting to a stop or leaving in one gear) cause damage to the motor since it's making it technically run lean? Or is it just an illusion to the ECU that the car is lean? Begin...
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: Discussion Topic: Car in neutral or downshift
When you are decelerating while still in gear and not giving the car any gas the ECU cuts the injectors off. When you are above 2.5k or so the injectors cut off to save gas and thats why it goes lean. This doesn't hurt anything since there is no load on the motor so it wont knock or anything. So it can save gas by decelerating while still in gear.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
The above point is correct. Also note that in most states it is illegal to coast in neutral.
Kris 2012 Genesis Coupe 2.0t |
Engine braking is often restricted for large vehicles (trucks and buses) around areas where Jake-braking can lead to noise pollution.
Coasting in neutral offers no control over the car aside from steering and brake input. Check your local laws and see if this is the case for you, but I've seen posts in a similar discussion indicate this is a common thing.
how the hell do they know that you cruising in neutral, and give you ticket ? or something ........
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold |
Say you let off the gas over 2.5k and coasting down. So the injectors are basically off, what if you suddenly go WOT? The computer is quick and all, but is there any chance that it wouldn't act quick enough and cause a little bit of leanness under load? Because any little bit of knock is bad. And I take it from the posts and some research that no matter what, as long as the car is not under load while lean, there's no damage being done right?
Knock is caused by heat. Heat comes from fuel. No fuel no heat.
If there is any law about coasting in nuetral, I would have to think it's emmissions related. The whole reasons all modern cars use DFC is for emissions. It also helps with fuel economy, so it makes sense to always coast down in gear.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
You may run a tiny bit lean but it wont hurt anything. The ECU is very quick at adding fuel back. And boost wont hit anywhere near that fast so your good.
The ECU has both accel and decel fuel pumps. Based on TPS delta values, some amount of IPW is added to what it is currently calling for, modifed by absolute TPS, temp, and RPM (among other things) instantly. The changes cab be made at the injector before the air can get there from the throttle body.
It's also worth mentioning that running lean only causes a problem because it creates heat. Heat build up takes time. Running lean for one or a handful of cycles doesn't break anything. Running lean for seconds at a time can do damage. In most cases a motor can take even long periods of running lean. I've had half track runs in the RWD at 40+ psi and 13.5 to 14.2 AFRs. I made full track runs in the EVO with the WG wired shut with a 75 shot on top of it at 14:1 (EVOs have awesome combustion chambers). In contrast, most motors will fail quickly with excessive timing. In other words, any amount of lean burn at low load is completely safe. In newer cars, the ECU is tuned from the factory to run very lean in some conditions for emissions and economy reasons. Etc.
Yea I have heard of a few people who run MS tune to 15 a/f ratios when cruising in town so try and get better gas milage.
That's only .3 leaner than stock, I was thinking more like 20:1. When DGI technology takes off, we'll be seeing a lot more lean burn strategy paying off.
When cruising my AFRs constantly vary from 15 to 17...thats about right right?
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
