Old 09-01-2008, 03:34 PM
zackmon zackmon is offline
crappy slowmaro
i have a 91 rs camaro 3.1 v6 replaced air intake sensor,iac,tps, map senser,swapped out engine control computer located under dash speaker on right side also swapped coil and replaced o2 senser. wil sit and idle perfectly, but as soon as the throttle is applied wants to die out and just chug. fuel pump is at 36 lbs any suggestions?
Old 09-02-2008, 03:33 AM
Morley Morley is offline
Re: crappy slowmaro
Check for a blocked cat converter and check for an EGR valve stuck open.
Old 09-02-2008, 07:27 PM
Re: crappy slowmaro
converter is hollowed out egr was swapped outstill the same situation
Old 09-04-2008, 07:09 PM
stoned_pimp420 stoned_pimp420 is offline
Send a message via Yahoo to stoned_pimp420
Re: crappy slowmaro
it's a 3.1 v6 in a camaro i've owned one and the best thing that happened to that car was that it got rearended, and it bought me a 305 camaro. the downside is that i've not owned a t-top car since.
I'm back after a long mental evaluation and heavy medication!
If you can't be a good example, you can always be a horrible warning!
