Old 09-01-2008, 09:54 AM
bombcitydavid bombcitydavid is offline
hondata s300
i have a 1990 hatch with h22 euro r . i have hondata s300 but do not no how to use it .the guy who set it up may not have same goals as me.(i want to outrun him he does not want me to) is there a web site i can go to to learn how to program my ecu myself.
Old 09-01-2008, 10:20 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: hondata s300
Hondata.com
Or, you can use Crome.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 09-01-2008, 11:14 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: hondata s300
Why would he go to a worse system when he already has one of the best?
The s300 is pretty simple to learn to use. its more "how to tune" that is the hard part.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 09-01-2008, 11:17 AM
Re: hondata s300
"Or you can use Crome" was me being sarcastic... as in, if you can't figure out how to use the system, you probably should be using crome... or turbo-edit... since they both do the "work" for you.
But, I can't say much, b/c I usually figure out what I want, then have someone else edit the hex/binary for me. I'm Lazy.
Old 09-01-2008, 11:32 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: hondata s300
Most of this isn't specifically for Hondata, or is about another EMS completely, but the basic info should be useful.
http://www.hondata.com/techtuning.html
http://www.importbuilders.com/tuningacar.htm
http://hondata.com/techwidebandtuning.html
http://www.importtuner.com/tech/0612...ics/index.html
http://racingarticles.com/article_racing-62.html
http://www.innovatemotorsports.com/r...fi-central.php
http://www.xenocron.com/te.php?page=fueltuning
http://home.comcast.net/~keebler65/honda/tuning.html
I strongly recommend picking up a book called "How to Tune and Modify Engine Management Systems". I only skimmed through the book before I let my friend borrow it, but in that short time I learned quite a bit of info I didn't know previously. It's also recommended reading for people who are going to take the EFI101 class.
Old 09-01-2008, 05:04 PM
Re: hondata s300
thanks civicspoon just what i needed.i also ordered the book.
