Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 09-01-2008, 06:23 AM
wade623's Avatar
wade623 wade623 is offline
machine rotors
how do you know when they need to be machined and why do they need it
Old 09-01-2008, 09:24 AM
bearcatdon bearcatdon is offline
Re: machine rotors
Some people like to turn the rotors with every brake job. Personally I only do it when deep gouges are present causing uneven pad wear or pulsation of the brake pedal during braking due to warpage.
Old 09-02-2008, 02:29 AM
wade623's Avatar
Re: machine rotors
i heard you need to do it every time you get new pads
__________________________________
Practice makes less imperfections.
Old 09-02-2008, 10:09 AM
bcopeland bcopeland is offline
Re: machine rotors
I agree with bearcatdon. Why turn your rotors when they are evenly worn? If you experience an unusual drive before you change the pads, then have then turned.
Old 09-02-2008, 08:41 PM
wade623's Avatar
Re: machine rotors
ok thanks
Old 09-24-2008, 06:37 AM
Reg Saretsky Reg Saretsky is offline
Send a message via AIM to Reg Saretsky
Re: machine rotors
IMHO- DON'T. A new rotor is 42.00 here in taxCanada- Cheaper in the USA. If you are going to the trouble of doing your own brakes- just slap a new rotor in.
Machining a rotor that is warped removes more metal to compensate for the warpage, leading to a more quickly warped rotor .
Old 09-24-2008, 10:51 AM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Re: machine rotors
Make sure you torque your lug nuts to the proper setting called by the manufacturer (usually 90-100 ft lbs). I used to get warped rotors every few months and since I started doing the torque procedure for about 6 to 8 years I've never had to turn the rotors on any of my cars.
Torque wrench are expensive but you can get a cheap one at Harbour Freight for about $20 and thats a lot better that guestimating your torque setting by hand alone!
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
