Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-31-2008, 11:39 PM
baredsss's Avatar
baredsss baredsss is offline
Question bucking & mising in midrange rpms
i have a 93 talon dohc turbo awd . ijust got it & know very little about the car or turbo systems
i do know it has a gm maf w/translator & the turbo looks a little bigger than
the stock one
my problem ,well the main one is that the car seems to be running extremly rich in the mid rs . it wil idle fairly good , but when it comes time to apply the throttle she bucks & spits really bad & if i can feather it through the rough it will take off like a rocket at around 4000 rs
installed new plugs & wires but minimal improvement
like i said i'm new to turbo cars & could use some insight please
thank you
Old 09-01-2008, 09:34 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: bucking & mising in midrange rpms
the stock one
thank you
Is there anything in there to tune with, like DSMLink or even a SAFC? You need something to control the fuel with if the turbo is upgraded and I think the GM MAF too. A 4g63 can help with that more.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-01-2008, 09:53 AM
baredsss's Avatar
the only thing that i know about is the maf translator , it has fuel adjustments in it , but it only helps a little
Old 09-01-2008, 11:54 AM
steviek's Avatar
steviek steviek is offline
Do you have a wideband Installed? Do you know what size injectors you are running? T|he Maf can be used as a mediocre tuning device but there are several other things we must know before we can give you helpful information.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 09-01-2008, 02:38 PM
baredsss's Avatar
No wide band. Nothing! didnt build it, just trying to figure it out.
BART
93 talon turbo awd 2.0 3" maf w/translator still in the pits trying to get it right
Old 09-01-2008, 07:57 PM
baredsss's Avatar
Exclamation Re: bucking & mising in midrange rpms
ithink i may have found the problem tps bad now this brings up another problem i can't find the proper tps that fits it has three wires coming out of it & a four wire plug , the fouth wire in the plug goes to the off idle switch on throttle body
anyone know where to find one????? the # on it is ewt-h8e
BART
Old 09-01-2008, 08:30 PM
baredsss's Avatar
sorry al i know is what ive told you but i need to find a tps for it it's the odd one w/ a 4 wire plug #ewt-h8e
BART
Old 09-01-2008, 08:32 PM
steviek's Avatar
http://cgi.ebay.ca/1G-DSM-4G63-Throt...QQcmdZViewItem
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 09-01-2008, 08:33 PM
steviek's Avatar
http://www.dsmparts.com/customer/pro...uctid=190&cat=
new
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 09-01-2008, 09:34 PM
baredsss's Avatar
no sorry wrong one mine hase wires attatched & has a round shaft o[pening instead of 2 fingers or pronges sticki out of throttle body i fond a picture of one & they identified it as a 90 64 mm throttle body but did not offer tps
BART
Old 09-01-2008, 09:41 PM
baredsss's Avatar
http://www.ffwdconnection.com/flow.shtml
the bottom pic is my set up & it has the right tps on it , does this help?
BART
Old 09-02-2008, 09:22 AM
steviek's Avatar
i found them here
http://www.trademotion.com/partlocat...&siteid=214828
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 09-02-2008, 09:42 PM
baredsss's Avatar
sad to say tps did not fix completly still searching for the culprit
BART
Old 09-16-2008, 08:17 PM
baredsss's Avatar
i8 just found out i have 510cc injectors in it
BART
