Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-31-2008, 07:41 PM
tahoe4x4guy tahoe4x4guy is offline
Cool 2001 tahoe coolant leak
With all of the input everyone has givin me i beleive the problem is the rear a/c unit which i think is a bad o ring. Thank you everyone for your input which is greatly appreciated.
Tahoe4x4guy.
Old 09-01-2008, 07:16 PM
j cAT j cAT is offline
Re: 2001 tahoe coolant leak
Tahoe4x4guy.
It is possible that someone put a green leak detector dye into your a/c refrigerent...if this connection is leaking carefully tighten nut only to point where it binds no more....with soapy water spray see if its leaking ..[bubbles]
you will need to dump your charge before this O ring if needed is replaced..
