Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-31-2008, 04:43 PM
mikeb55421 mikeb55421 is offline
Turn signals don't work
Got a 93 century. when you try and use the turn signal in any direction, nothing happens. Hazards still work fine, checked the fuses and all are fine, and just finished with replacing the turn signal switch in the steering column. wondering if it could be a relay. any input would be appreciated. thank you
Old 09-04-2008, 10:37 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Turn signals don't work
There are 2 separate flasher units, one for the hazards and one for the turn signals. The one for the turn signals is not in the fuse box, it's normally attached to the side of the steering column with a metal clip on the end of a two wire harness with one purple and one yellow wire. Once you find it, you can use the one from the hazards to test (they are the same part number). If they still don't work with the hazard flasher in there, then you have a wiring issue.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
