Old 08-31-2008, 02:49 PM
JoeSonoma JoeSonoma is offline
Question Greasing light bulbs before install?
A friend of mine suggested that I grease the metal contact points of light bulbs on my 1991 GMC Sonoma when I change them, to avoid having them get stuck later on (I just had to remove a stuck one, very nasty).
For break, backup, turn signal, hood light, etc.
Has anyone tried this, or know if it's safe? My friend does it on all of his trucks with no problem, but I'm still a little unsure about it.
Old 08-31-2008, 06:36 PM
maxwedge maxwedge is offline
A990 racer
Re: Greasing light bulbs before install?
I would not use just plain grease here , if you want to do this use di-electric grease.
Old 09-01-2008, 01:55 AM
partsmgn's Avatar
partsmgn partsmgn is offline
Di-electric grease is used anywhere moisture and corrosion are more frequent...use it also on your trailer plug-in also. Another product you might be able to use is in a spary can it's mainly used on ignition componets to prevent water from drowning out your plug wires. (unfortunatly I forget what it was called) but most automotive stores carry it
Old 09-01-2008, 02:13 AM
Scrapper Scrapper is offline
AF Premium User
yah and don't use that much when you do put them in.i've seen them globbed in there a no need to have that much grease..but yes a little grease.
Old 09-01-2008, 02:15 AM
AF Premium User
Wellyou All Have A Good Week End And Be Safe..oh Yah Get Drunkkkk.
Old 09-01-2008, 02:17 AM
AF Premium User
Originally Posted by scrapper1
Well you All Have A Good Week End And Be Safe..oh Yah Get Drunkkkk.
OOPS
Old 09-01-2008, 11:40 AM
Smile Re: Greasing light bulbs before install?
OOPS
LOL! Don't worry about the mispost, I've done it before too.
Thanks for the info guys! I'll check NAPA auto parts and see what they've got in that catagory.
