Old 08-31-2008, 01:46 PM
OldsBuickGuy82 OldsBuickGuy82 is offline
Radio Reception Interference...What can it be?
Hi,
I have a 1995 Oldsmobile Eighty-Eight with radio reception problems. The bottom line is that if I shut the car off and just put the key back, I can get near perfect FM reception, but once the car is started I get nothing on FM. I've checked everything that I can think of and come up with nothing. What can be causing the interference?
Thanks
Old 08-31-2008, 06:16 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Radio Reception Interference...What can it be?
you are getting an EMI from somewhere, did you change the spark plug wires or have you checked them. Some type have a lot of EMI output, it can also be caused be a cracked one.
Old 09-01-2008, 12:49 PM
There was no reception when I bought the car, then I bought a new engine and had that installed, and still have nothing. I can't say for sure, but I think the plug wires in there now are the ones from the new engine, not the olds set. Anything I can try to check if this might be the problem?
Old 09-01-2008, 05:33 PM
Audio Guy
ohhhh ... that's different.
Your radio antenna is most likely either not connected to the radio or broken somewhere
Old 09-02-2008, 06:24 PM
AWP9521 AWP9521 is offline
Check your Coax Cable at the antenna end too and see if it is plugged in there, some cables can be disconnected at the antenna end for easier replacement should the antenna get damaged.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 09-02-2008, 07:11 PM
I've checked all cables, the antenna is new, the cd/stereo is also new (a new to me factory replacement). Everything has been checked a million times. And until the car is started (key just turned back) there is perfect reception, but nothing once the engine is actually running. The problem was there before any of the above things were replaced or checked.
Old 09-03-2008, 05:18 PM
Audio Guy
Sorry I know very little to nothing about OEM stuff. These are the problems I hate troubleshooting.
