Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-31-2008, 11:18 AM
vzfox vzfox is offline
IAC testing
What steps or procedures do I need to take to test my IAC on a 95 Eclipse 2.0L non turbo?
Old 09-04-2008, 12:07 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: IAC testing
You test the resistence between pins 1 and 4, and test 2 and 3. I believe you should get around 35ohms at 70F
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-04-2008, 05:39 PM
Re: IAC testing
Not only is it extremely difficult to test these small/thin pins with my mulitmeter, but no matter how many times I tried I got readings ranging from nothing to 120 ohms and readings in between.
But you did answer my question.....so kudos to you. thanx.
Old 09-04-2008, 07:07 PM
CoolasIce CoolasIce is offline
Re: IAC testing
It could still be bad, couldn't it?
The pintle might not move freely.
Old 09-04-2008, 08:04 PM
Re: IAC testing
This is my whole main issue.....do I spend money on the IAC or ask for assistance here on testing as much as I can before possibly wasting money.
Old 09-04-2008, 09:40 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: IAC testing
Buy a new one and that's not your problem, then you have a spare or you can sell it on eBay or something.
Buy a new one and it is your problem, well, problem solved.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-04-2008, 10:49 PM
Holset powered 420a
Re: IAC testing
Buy a new one and if it doesn't fix the problem then take it back.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-05-2008, 07:27 AM
Re: IAC testing
point taken......I will stop and get one on my way home today. $53 at autozone. Them things arent cheap.
I should know by tonight or possibly tomorrow if my problem is resolved.....I'll let you guys know.
Old 09-05-2008, 07:35 AM
david-b's Avatar
Dave is THAT guy
Re: IAC testing
I paid $60 for mine, and have replaced 2. The ISC on the 4g63 motors are like what $200+. Ours is pretty decent. Hope that fixes the problem. Good luck.
75 Monte Carlo
Old 09-05-2008, 08:11 PM
Thumbs up Re: IAC testing
Well.....bought the new IAC and installed it today. IDLES LIKE A NEW CAR
It was a bit expensive for my low budget taste, but gotta do whatcha gotta do. Thanx guys for all the assist.
One more small insugnifigant question.......Why does the a/c switch have two settings? both blow cold air, but one setting lights up "yellow" and the other setting lights up "green".
